Ultra Low Power,在指挥/ API控制,Sigfox(R)兼容收发器IC的上行和Down Link
消耗积分:0 | 格式:rar | 大小:0.19 MB | 2017-03-28
分享资料个
  Circuit Description AX−SFUS and AX−SFUS−API are ultra−low power single chip solutions for a node on the Sigfox network with both up− and down−link functionality. The AX−SFUS chip is delivered fully ready for operation and contains all the necessary firmware to transmit and receive data from the Sigfox network in the US (SIGFOX RCZ2 region)。 It connects to the customer product using a logic level RS232 UART. AT commands are used to send frames and configure radio parameters. The AX−SFUS−API variant is intended for customers wishing to write their own application software based on the AX−SF−LIB−1−GEVK library
评论(0)
发评论
下载排行榜
