FEATURES DESCRIPTION 2• LOW VOLTAGE NOISE: 2.2nV/√Hz at 1kHz The OPA209 series of precision operational • 0.1Hz to 10Hz NOISE: 130nV amplifiers achieve very low voltage noise density PP (2.2nV/√Hz) with a supply current of only 2.5mA • LOW QUIESCENT CURRENT: 2.5mA/Ch (max) (max)。 This series also offers rail-to-rail output swing, • LOW OFFSET VOLTAGE: 150mV (max) which helps to maximize dynamic range. • GAIN BANDWIDTH PRODUCT: 18MHz In precision data acquisition applications, the • SLEW RATE: 6.4V/ms OPA209 provides fast settling time to 16-bit accuracy, • WIDE SUPPLY RANGE: even for 10V output swings. This excellent ac ±2.25V performance, combined with only 150mV (max) of to ±18V, +4.5V to +36V offset and low drift over temperature, makes the • RAIL-TO-RAIL OUTPUT OPA209 very suitable for fast, high-precision • SHORT-CIRCUIT CURRENT: ±65mA applications. • AVAILABLE IN SOT23-5, MSOP-8, SO-8, AND The OPA209 is specified over a wide dual TSSOP-14 PACKAGES power-supply range of ±2.25 to ±18V, or single-supply operation from +4.5V to +36V. APPLICATIONS The OPA209 is available in the SOT23-5, MSOP-8 • PLL LOOP FILTERS and the standard SO-8 packages. The dual OPA2209 • LOW-NOISE, LOW-POWER SIGNAL comes in both MSOP-8 and SO-8 packages. The PROCESSING quad OPA4209 is available in the TSSOP-14 • LOW-NOISE INSTRUMENTATION AMPLIFIERS package. • HIGH-PERFORMANCE ADC DRIVERS The OPA209 series is specified from –40°C to • HIGH-PERFORMANCE DAC OUTPUT +125°C. AMPLIFIERS • ACTIVE FILTERS • ULTRASOUND AMPLIFIERS • PROFESSIONAL AUDIO PREAMPLIFIERS • LOW-NOISE FREQUENCY SYNTHESIZERS • INFRARED DETECTOR AMPLIFIERS • HYDROPHONE AMPLIFIERS
