LM94022/LM94022Q,datasheet,pdf
消耗积分:3 | 格式:rar | 大小:550 | 2009-10-20
王秀兰
分享资料个
The LM94022 is a precision analog output CMOS integratedcircuit
temperature sensor that operates at a supply voltage
as low as 1.5 Volts. A class-AB output structure gives the
LM94022 strong output source and sink current capability for
driving heavy loads. For example, it is well suited to source
the input of a sample-and-hold analog-to-digital converter
with its transient load requirements. While operating over the
wide temperature range of −50°C to +150°C, the LM94022
delivers an output voltage that is inversely porportional to
measured temperature. The LM94022's low supply current
makes it ideal for battery-powered systems as well as general
temperature sensing applications.
评论(0)
发评论
下载排行榜
