1. General description The TDA1308; TDA1308A is an integrated class-AB stereo headphone driver contained in an SO8, DIP8 or a TSSOP8 plastic package. The TDA1308AUK is available in an 8 bump wafer level chip-size package (WLCSP8). The device is fabricated in a 1 µm Complementary Metal Oxide Semiconductor (CMOS) process and has been primarily developed for portable digital audio applications. The difference between the TDA1308 and the TDA1308A is that the TDA1308A can be used at low supply voltages. 2. Features n Wide temperature range n No switch ON/OFF clicks n Excellent power supply ripple rejection n Low power consumption n Short-circuit resistant n High performance u High signal-to-noise ratio u High slew rate u Low distortion n Large output voltage swing
