纳米模块重新定义低功耗DC / DC转换
消耗积分:0 | 格式:rar | 大小:0.33 MB | 2017-05-22
分享资料个
  无论是为电信基础设施或工业机器人,更多的功能和功能被添加到系统板,减少了可用的电源空间。例如,在计算机中的分布式电源架构,其中的负载点(DC)的稳压器和DC / DC转换器的要求是尽可能小。此外,这些DC / DC转换器模块必须使用最少数量的外部元件,并提供高效率的快速瞬态响应。小于50平方毫米大小,这些微小的电源也必须表现出优异的电磁干扰(EMI)性能。换言之,尽管开关频率高,使用的集成电感器必须做好屏蔽,以保持射频发射到最低限度,使他们满足所需的监管合规性。现在添加到混合工程师的偏好可扩展性,因为它可以很容易地升级模块,而不改变印刷电路板。两者合计,这是一个艰巨的要求清单。
  保持这些新的现代电力产品的需求,德克萨斯仪器已扩大其流行的简单开关直流/直流转换器家庭与四个新成员称为纳米模块。专为空间受限的POL应用,包括直流/ DC转换器高达17 V,四纳米模块允许设计人员添加新的功能,保持较高的效率,解决辐射干扰的要求,并适应更小的同时保持设计过程简单,系统成本低。从本质上讲,纳米模块最大限度地提高功率密度和热性能,同时保持简单和低成本。
  Nano Power Modules
  There are two versions: the 5 V parts, which include LMZ20501 and LMZ20502 deliver up to 2 A output current at an adjustable output voltage of 0.8 V to 3.6 V, while the higher 17 V version LMZ21700/01 is rated up to 1 A of output current at 0.9 V to 6.0 V output voltage. Offering sizes as small as 30 mm2, the Nano Modules are 40 percent smaller than a discrete implementation and feature low EMI to comply with the CISPR (class B) radiated and conducted EMI standard. The 17 V, 1 A part LMZ21701, for example, comes in a miniature package measuring 3.5 x 3.5 x 1.75 mm, and incorporates the controller/logic, power MOSFETs, and the high-frequency inductor, along with other pulse-width modulated (PWM) functions in this tiny package (Figure 1)。 As a result, it offers a complete step-down DC/DC converter solution capable of driving up to 1 A load in space-constrained applications like network security cameras, factory automation, and industrial robots.
  Although the input voltage range for LMZ21701 is 3 to 17 V, it is primarily intended for 5 V or 12 V input applications. Because the Nano Module is highly integrated, only an input capacitor, an output capacitor, a soft-start capacitor, and two resistors are required externally for basic step-down DC/DC conversion, as shown in Figure 2. As a quick start, the product data sheet provides external component values for output voltages from 1.2 V to 5.0 V.
评论(0)
发评论
下载排行榜
