建立一个交流/直流转换器是易与PI Expert
交流电源供电的孤立的离线开关需要在许多应用中,从家用电器到适配器对电池充电。这些孤立的AC / DC转换器从头开始设计可以压倒一切,消耗更多的时间,并可以花费更多。因此,为了使这项工作容易,灵活,成本效益,电源集成创造了一套工具和资源。除了帮助设计师开发和建立这些离线AC / DC开关在市场上有竞争力的价格,电力集成的工具和资源,同时提高设计师在第一次尝试通过监管要求的机会,从而消除了开发和交付的麻烦。
为了实现这一目标,供应商已经准备两集成开关IC的家庭,即电源转换和TinySwitch III(TNY253 / 4 / 5和tny274gn或tny278gn),使电源设计人员的任何应用程序在177 W而TinySwitch部分是专为需要25瓦或更少的输出功率AC / DC开关应用的构建AC / DC开关,TOPSwitch的JX家族是专为AC / DC解决方案高达177 W和建设交流/直流使用这两个系列的成员交换机的设计,电源集成了免费设计的软件称为PI Expert。
Low-power AC/DC solutions
However, before we start exploring the PI Expert design software; let’s take a look at the functionalities integrated on-chip for switcher ICs TinySwitch-III and TOPSwitch-JX. Since TinySwitch is tailored for AC/DC solutions below 25 W, we will first investigate the TinySwitch landscape. As shown in Figure 1, TinySwitch combines a 700 V power MOSFET, oscillator, high-voltage switched current source, current limit, and thermal shut-down circuitry on a single CMOS chip. As per the product data sheet, the start-up and run-on power is derived from the drain voltage, thereby eliminating the need for a transformer bias winding and its associated circuitry. It is rated to consume only about 80 mW at no load from 265 VAC input. A simple on/off control scheme also eliminates the need for loop compensation, according to the supplier.
