电池电源管理选项的SEPIC
单端初级电感转换器(SEPIC)是一种DC-DC电压转换器(“器”),能够升压(boost)和降压(“巴克”)输入电压;从当硅电压要求是高于电池的低压范围内获得最大容量的电池有用的特征。
传统的降压/升压转换器可以做到这一点,但SEPIC具有许多优点在其传统的对应。本文介绍了SEPIC稳压器的拓扑结构及其优点,并回顾了一些最新的SEPIC型功率模块。
Maximizing battery capacity
As a battery discharges its output voltage diminishes. For example, a single lithium-ion (LI-ion) battery supplies 4.2 V when fully charged, dropping to 3 V at the end of discharge point. Figure 1 shows a Li-ion discharge curve under a load of 0.2 C (where C is the battery’s rated capacity in ampere-hours. The battery would therefore be expected to last five hours under this load)。
