LED调光解决方案
随着住宅和商业客户的变化,从白炽灯甚至CFL到LED照明,LED灯市场呈指数增长。其典型原因是功率效率高,寿命长。然而,客户也希望白炽灯的LED灯具有相同的特性,特别是能够使光线变暗的能力,因为它提供了合适的环境,有助于节约能源。乍一看,在调光器中设计似乎很简单,但实际上它是非常有挑战性的,因为LED和白炽灯的工作方式不同,如果不正确的话,调光器会导致LED灯闪烁,以及降低调光范围和不一致的性能。在调光过程中,LED灯在传统的LED调光电路上显示出明显而明显的闪烁现象。直接连接到线路电压白炽灯调光器的LED驱动器也可能没有足够的功率在较低的调光电平下工作,也可能受到电流尖峰的损坏。另一个闪烁源是电源不稳定。如果电源有下降,灯就会关掉,在灯的驱动电路试图保持光输出恒定的情况下产生明显的闪烁。
白炽灯
目前,住宅和商业照明控制设备是为白炽灯而设计的。白炽灯是一种简单的电阻性负载,对调光器设定点具有线性响应。LED灯负载可以在不同的制造商的灯具和设计有很大的变化,但大多数可以表征二极管电容器供电的恒流源。二极管校正所施加的交流电压,允许它对储能电容充电,而LED元件从与预期的调光电平和亮度相关的电源中绘制恒定电流。
LED lamps
LED lamps have a nonlinear relationship, and the applied voltage and current flowing into the load are related. The incandescent lamp load, applied voltage across the load, and the resulting current flowing through the load, are related linearly.
In LED loads, the applied voltage and resulting current flow are not related by a simple linear relationship. In the diode-capacitor power-supply model of the LED lamp, current flows from the applied voltage to the load only when the magnitude of the applied voltage exceeds the stored voltage on the power supply capacitor (Figure 1)。 The stored voltage on the power supply capacitor, in turn, depends on the current drawn by the LED elements themselves, which is a function of the LED brightness.
