LED阵列的有效的热管理
LED阵列的性能、可靠性和设计寿命在很大程度上取决于适当的热管理。本文探讨了各种传导,对流和辐射技术,以帮助确保最佳的性能和长寿命为您的下一个照明设计
介绍
Bridgelux家族的LED阵列产品提供高性能,结构紧凑,并为通用照明市场性价比的固态照明解决方案。这些产品结合了LED的高效率,寿命和可靠性的好处与许多传统照明光源的光输出水平。
正如在普瑞LED阵列产品的说明书,一些性能特点的LED阵列产品,包括流量、正向电压、颜色、和可靠性依赖于温度。这是所有LED的一个共同特点,这是半导体技术的一个特点。随着温度的升高,一些性能参数经历了暂时的和可恢复的变化。随着温度的升高,光输出(或光通量)减小,正向电压(或VF)减小,色温转变为蓝色。
此外,绝对最大额定值,如最大温度和最大结温,不得超过。超过绝对最大额定值,如在产品数据表列,可能不可逆损害产品和导致性能的永久性的变化。。
Optimization of performance and reliability in a lighting system using Bridgelux LED Arrays requires proper thermal management. Although a critical design parameter, thermal management is not as difficult as many would believe. Understanding the basics allows every lighting designer to optimize his product and meet specification requirements.
This article describes basic thermal management concepts and guidelines for proper use of Bridgelux LED Arrays in a lighting system. Included is an overview of basic heat transfer concepts, a description of a thermal model, a sample calculation using this thermal model, a description of various thermal components, and recommendations for measuring the case temperature of the Bridgelux LED Array to validate the performance of the thermal management solution.
