10M CXP-CXP光源电缆参数:1.Full Duplex 12 Channel 850nm Parallel Active Optical Cable.2.Supports transmission rates up to 10.3Gbit/s per channel.3.CXP-based module at one end and QSFP-based modules at the other ends.4.Hot pluggable electrical interfaces.5.CXP-based module supports Rx Pre-Emphasis.6.EEPROM-based Serial-ID, accessible through two-wire Serial Interface.
