G3电力线通信数据集中器设计指南
消耗积分:1 | 格式:rar | 大小:0.19 MB | 2017-09-15
分享资料个
  TI Designs
  TI Designs provide the foundation that you need including methodology, testing, and design files to quickly evaluate and customize the system. TI Designs help you accelerate your time to market.
  Design Resources
  TIDEP0023Tool Folder Containing Design Files
  PLC KitMore Information on PLC Kit
  G3 DC SoftwareMore Information on G3 DC Software
  BeagleBone BlackMore Information on BeagleBone Black
  ASK Our E2E Experts
  WEBENCH® Calculator Tools
  Data concentrator with BeagleBone BLACK
  Host PC
  (Terminal)
  Data concentrator Service node
  BeagleBone Black½ TMDSPLCKITV4 ½ TMDSPLCKITV4
  USB-RS232BeagleBonePLC modemPowerlinePLC modemHost PC
  bridge(Terminal)
  BLACK
  (CMOS)
  Legend: Modem SubSystem
   Processor SubSystem
  Supporting function
  Design Features
  • Simplified, Cost-Effective Solution for Evaluating G3-Power Line Communications (PLC) Using BeagleBone Black (BEAGLEBK) and TI‘s PLC Modem Kit (TMDSPLCKITV4-CEN kit)
  • Forms a Small End-to-End G3-PLC Network Using Two Modems from TMDSPLCKIT Kit:
  – One for Data Concentrator PHY and One for Service Node
  • Demonstrates Single-Phase Coupling
  • Based on Kits Available from the TI Store or Distributors that Include Linux Applications, Middleware, Drivers, Hardware Schematics, Bill of Materials, and Design Files
  Design Description
  This PLC Data Concentrator design offers a simplified approach for evaluating G3-PLC using BeagleBone Black powered by the Sitara™ AM335x processor. Users can establish a G3-PLC network with one service node. This design supports single-phase coupling.
  An IMPORTANT NOTICE at the end of this TI reference design addresses authorized use, intellectual property matters and other important disclaimers and information.
  All trademarks are the property of their respective owners.
  SPRUHT4 –May 2015G3 Power Line Communications Data Concentrator on BeagleBone Black1
  Submit Documentation FeedbackPlatform Design Guide
  Copyright © 2015, Texas Instruments Incorporated
  Required Hardware www.ti.com
  1 Required Hardware
  • One Linux computer, or a virtual machine running Linux
  • One microSD (2GB+)
  • One BeagleBone black board
  • One TMDSPLCKITV4 kit
  • One FTDI-RS232 bridge
  2 Step-by-Step Description
  This walkthrough will enable users to build a G3 PLC network with one node. Users can build up a PRIME PLC network in a similar fashion. Users will also learn how to configure and compile a Linux kernel required for this task.
  Create a Standard Image on an SD Card
  The base for this DC image will be the default image provided by the TI SDK. To modify the image:
  1. Install the latest SDK on your Linux machine (or virtual machine)。
  (a) Download the latest SDK, here “ti-sdk-am335x-evm-07.00.00.00-Linux-x86- Install.bin” from http://software-dl.ti.com/sitara_linux/esd/AM335xSDK/latest/index_FDS.html.
  (b) Install the package on the Linux machine using a console window.
  。/ti-sdk-am335x-evm-07.00.00.00-Linux-x86-Install.bin
  Use the suggested directory, for example /home/user/ti-sdk-am335x-evm-07.00.00.00/。
  NOTE: The abbreviation through the guide for this path is $SDK.
  2. Make an SD card (2GB or more) available to the Linux machine and install the standard (pre-built) image on it.
  cd $SDK/bin
  sudo 。/create-sdcard.sh
  Options: Create two partitions and use the pre-built image.
  3. If necessary, remove and insert the SD card to mount it properly to the Linux environment.
评论(0)
发评论
下载排行榜
