数字锁DRV5013霍尔效应传感器
消耗积分:0 | 格式:rar | 大小:1.26 MB | 2017-09-22
分享资料个
  The DRV5013 device is a chopper-stabilized Hall Effect Sensor that offers a magnetic sensing solution with superior sensitivity stability over temperature and integrated protection features. The magnetic field is indicated via a digital bipolar latch output. The IC has an open-drain output stage with 30-mA current sink capability. A wide operating voltage range from 2.5 to 38 V with reverse polarity protection up to –22 V makes the device suitable for a wide range of industrial applications. Internal protection functions are provided for reverse supply conditions, load dump, and output short circuit or over current.
数字锁DRV5013霍尔效应传感器
评论(0)
发评论
下载排行榜
