btn8982ta高电流PN半桥novalith IC
消耗积分:0 | 格式:rar | 大小:1.83 MB | 2017-09-23
分享资料个
  The BTN8982TA is an integrated high current half bridge for motor drive applications. It is part of the NovalithIC™ family containing one p-channel highside MOSFET and one n-channel lowside MOSFET with an integrated driver IC in one package. Due to the p-channel highside switch the need for a charge pump is eliminated thus minimizing EMI. Interfacing to a microcontroller is made easy by the integrated driver IC which features logic level inputs, diagnosis with current sense, slew rate adjustment, dead time generation and protection against overtemperature, undervoltage, overcurrent and short circuit. The BTN8982TA provides a cost optimized solution for protected high current PWM motor drives with very low board space consumption.
评论(0)
发评论
下载排行榜
