as1301 pdf datasheet
消耗积分:5 | 格式:rar | 大小:555 | 2008-07-29
罗星
分享资料个
The AS1301 is a 50mA inductorless boost converter using a double H-bridge charge-pump topology with two small (≤220nF) external flying capacitors.
The AS1301 runs on a 1MHz fixed frequency and is utilized with a low noise regulation scheme to allow usage together with sensitive RF circuitry from the same battery supply.
Designed to reside in portable and space limited equipment the 1MHz charge pump converts a 2.7 to 5.25V input to regulated 5V output with 5% accuracy.
The shutdown function reduces the supply current to <5μA and disconnects the load from the output. The integrated soft-start circuitry prevents current spikes being drawn from the battery during start-up.
The AS1301 is available in TDFN (3x3x0.8mm) 10-pin and WL-CSP 8-bumps packages.
评论(0)
发评论
下载排行榜
