skw78 4x4 MIMO WLAN 模块数据
消耗积分:0 | 格式:pdf | 大小:1100KB | 2017-10-20
天工测控
分享资料个
AC模块_WiFi模块_5G WIFI模块,本文档介绍了5G WIFI模块的一些基本情况和特征
  The SKW78 module compliant to 802.11 a/b/g/n/ac Wi-Fi Solution, It integrates a dual-core MIPS1004Kc (880MHz), 3-port GbE switch, USB2.0, SD-XC. The module is suitable for 802.11ac, LTE cat4/5, edge, hotspot, VPN, AC (Access Control)。 For consumer electronic devices, the module requires only an external 3.3V power supply. The module integrates a 2.4GHz 2x2 MIMO WLAN chip with internal PA and LNA and integrates a 5GHz 2x2 MIMO WLAN chip with internal PA and LNA. It supports 2.4GHz operations up to 144 Mbps for 20 MHz and 300 Mbps for 40 MHz channel respectively, and supports 5GHz operations up to 866 Mbps for 80 MHz channel respectively. The module support Bridge mode and AP/ Client mode and Gateway mode.
评论(0)
发评论
下载排行榜
