FT-7900R_SM_USA_EXP_EH016M93A
消耗积分:1 | 格式:pdf | 大小:3147KB | 2017-10-21
無銘軒BI4KYT
分享资料个
FT-7900R维修手册
  VHF Reception
  The incoming VI IF signal is passed through a low-pass
  filter network,antenna sw itc hingdiodes D1074 (RLS135),
  D1075 (RLS135) and D1015 (HVC131),and another low-
  pass filter network to the RF amplifier Q1008(3SK296ZQ)。
  The amplified RF signal is passed through a varactor con-
  trolled bandpass filter consisting of L1017,L1018,and
  D1010,D1011,and D1012 (all HVC365),then applied to
  the first mixer Q1009 (3SK296ZQ) along w ith the first
  local signal from the PLL circuit.
  The first local signal is generated between 189.05 MHz
  and 193.05 MI 1z,depending on the receiving frequency,
  by the VHF \ C O,w hic h consistsof Q1076(2SC5374) and
  varactor diodes D1049 (HVC365),D1050 (HVC131),
  D1051(HVC365),and D1052 (HVC362)。
  UHF Reception
  The incoming UHF signal is passed through a low-pass
  filter network,antenna switching diodes D1077
  (MA4P1250) and D1018(RLS135),D1019(RLS135),and
  D1084 (HSC277),and another low-pass filter network to
  the RF amplifier Q1001(3SK296ZQ).The amplified RF
  signal is passed through a varactor-controlled band-pass
  filter consisting of L1006 and L1007,and D1002,D1003,
  and D1004 (all HVC350B),then applied to the first mixer
  Q1002 (3SK296ZQ) along w ith the first local signal from
  the PLL circuit.
  The first local signal is generated between 384.95 MI Iz
  and 404.95 MHz,depending on the receiving frequency,
  by the UHF V CO,w hich consists of Q1072 (2SC5006)
  and varactor diodes D1046 (HVC375B) and D1047
  (HVC350B).
.FT-7900R_SM_USA_EXP_EH016M93A
评论(0)
发评论
下载排行榜
