台湾矽创ST7290液晶控制器datasheet
消耗积分:1 | 格式:pdf | 大小:1766KB | 2017-10-26
闫錚
分享资料个
原版台湾矽创st7290控制器资料,很多12864屏控制器都是由此而来!
  ST7920 LCD controller/driver IC can display alphabets, numbers, Chinese fonts and self-defined characters. It supports 3 kinds of bus interface, namely 8-bit, 4-bit and serial. All functions, including display RAM, Character Generation ROM, LCD display drivers and control circuits are all in a one-chip solution. With a minimum system configuration, a Chinese character display system can be easily achieved. ST7920 includes character ROM with 8192 16x16 dots Chinese fonts and 126 16x8 dots half-width alphanumerical fonts. Besides, it supports 64x256 dots graphic display area for graphic display (GDRAM)。 Mix-mode display with both character and graphic data is possible. ST7920 has built-in CGRAM and provide 4 sets software programmable 16x16 fonts. ST7920 has wide operating voltage range (2.7V to 5.5V)。 It also has low power consumption. So ST7920 is suitable for battery-powered portable device. ST7920 LCD driver consists of 32-common and 64-segment. Company with the extension segment driver (ST7921) ST7920 can support up to 32-common x 256-segment display
评论(1)
发评论
lee6658 2021-05-25
0 回复 举报
资料有错误 不是ST7290的资料 下载的是ST7920的资料 收起回复
下载排行榜
全部1条评论
