MAX6621,pdf datasheet (PECI-to
消耗积分:5 | 格式:rar | 大小:433 | 2009-12-12
王越建
分享资料个
The MAX6621 PECI-to-I²C translator provides an efficient, low-cost solution for PECI-to-SMBus™/I²C protocol conversion. The PECI-compliant host reads temperature data directly from up to four PECI-enabled CPUs. Interrupts are generated when the measured temperature exceeds the high-temperature limit and causes the active-low ALERT to assert. The active-low RESET input allows the host to reset the I²C bus in the event of a communication error.
The I²C interface provides an independent serial communication channel to communicate synchronously with peripheral devices in a multiple master or multiple slave system. This interface allows a maximum serial-data rate of 400kbps.
The MAX6621 is designed to operate from a +3.0V to +3.6V supply voltage and ambient temperature range of -20°C to +120°C.
评论(0)
发评论
下载排行榜
