• Clock frequency: 200, 166, 143, 133 MHz
• Fully synchronous; all signals referenced to a positive clock edge
• Internal bank for hiding row access/precharge
• Single 3.3V power supply
• LVTTL interface
• Programmable burst length
– (1, 2, 4, 8, full page)
• Programmable burst sequence:
Sequential/Interleave
• Self refresh modes
• Auto refresh (CBR)
• 4096 refresh cycles every 64 ms (Com, Ind, A1 grade) or 16ms (A2 grade)
• Random column address every clock cycle
• Programmable CAS latency (2, 3 clocks)
• Burst read/write and burst read/single write operations capability
• Burst termination by burst stop and precharge command
•时钟频率:200, 166, 143,133兆赫
完全同步;所有参考正时钟边沿的信号
•隐藏行访问/预充电的内部银行
•单3.3V电源
•LVTTL接口
可编程突发长度
-(1, 2, 4,8,整页)
可编程突发序列:
顺序/交织
•自我刷新模式
•自动刷新(CBR)
•4096刷新周期每64毫秒(COM,Ind,A1级)或16ms(A2级)
•每个时钟周期的随机列地址
•可编程CAS延迟(2, 3个时钟)
•突发读写和突发读/写操作能力
•突发停止和停止预充电命令终止
