MC34716,pdf datasheet (1.0 MHz
消耗积分:3 | 格式:rar | 大小:444 | 2010-01-12
370217
分享资料个
The MC34716 is a highly integrated, space-efficient, low cost, dual synchronous buck switching regulator with integrated N-channel power MOSFETs. It is a high performance point-of-load (PoL) power supply with its second output having the ability to track an external reference voltage. it provides a full power supply solution for Double-Data-Rate (DDR) Memories.
Channel one provides a source only, 5.0 A drive capability, while channel two can sink and source up to 3.0 A. Both channels are highly efficient with tight output regulation. With its high current drive capability, channel one can be used to supply the VDDQ to the memory chipset. The second channel’s ability to track a reference voltage makes it ideal to provide the termination voltage (VTT) for modern data buses. The 34716 also provides a buffered output reference voltage (VREFOUT) to the memory chipset
The 34716 offers the designer the flexibility of many control, supervisory, and protection functions to allow for easy implementation of complex designs. It is housed in a Pb-free, thermally enhanced, and space efficient 26-Pin Exposed Pad QFN.
评论(0)
发评论
下载排行榜
