MP1410 pdf datasheet (MPS)
消耗积分:10 | 格式:rar | 大小:444 | 2008-08-06
48674
分享资料个
The MP1410 is a monolithic step down switch
mode regulator with a built in internal Power
MOSFET. It achieves 2A continuous output
current over a wide input supply range with
excellent load and line regulation.
Current mode operation provides fast transient
response and eases loop stabilization.
Fault condition protection includes cycle-bycycle
current limiting and thermal shutdown. In
shutdown mode the regulator draws 25μA of
supply current.
The MP1410 requires a minimum number of
readily available standard external components.
评论(0)
发评论
下载排行榜
