AAT3111,pdf datasheet(MicroPow
消耗积分:2 | 格式:rar | 大小:221 | 2010-01-30
安立路
分享资料个
The AAT3111 ChargePump is a MicroPower switched capacitor voltage converter that delivers a regulated output. No external inductor is required for operation. Using three small capacitors, the AAT3111 can deliver up to 150mA to the voltage regulated output. The AAT3111 features very low quiescent current and high efficiency over a large portion of its load range, making this device ideal for battery-powered applications. Furthermore, the
combination of few external components and small package size keeps the total converter board area to a minimum in space-restricted applications.
评论(0)
发评论
下载排行榜
