AAT3132/AAT3132A,pdf datasheet
消耗积分:2 | 格式:rar | 大小:221 | 2010-01-30
丁冬芹
分享资料个
The AAT3132/32A is a low noise, constant frequencycharge pump DC/DC converter that uses fractional (1.5X) conversion to maximize efficiency for white LED applications. The device can be used to produce current levels up to 20mA in three of its outputs
and up to 25 or 30mA in one of its outputs to drive LEDs from a 2.7V to 5.5V input. Outputs may be operated individually or paralleled for driving higher-current LEDs. A low external parts count (two 1μF flying capacitors and two small 1μF capacitors at VIN and OUT) makes the AAT3132/32A ideally suited for small battery-powered applications.
评论(0)
发评论
下载排行榜
