AAT3164,pdf datasheet(Six-Chan
消耗积分:3 | 格式:rar | 大小:221 | 2010-01-30
杨海清
分享资料个
The AAT3164 is a low noise, constant frequency charge pump DC/DC converter that uses a trimode load switch (1X), fractional (1.5X), and doubling (2X) conversion to maximize efficiency for white LED applications. The device is capable of driving up to six channels of LEDs at up to 30mA per channel from a 2.7V to 5.5V input. The current sinks may be operated individually or in parallel for driving higher-current LEDs. A low external parts count (two 1μF flying capacitors and two small 1μF capacitors at IN and OUT) makes this part ideallysuited for small, battery-powered applications.
评论(0)
发评论
下载排行榜
