The AAT3169 is a low noise, constant frequency charge pump DC/DC converter that uses a tri-mode load switch(1X), fractional (1.5X), and doubling (2X) conversion tomaximize efficiency for white LED applications. TheAAT3169 is capable of driving six LEDs for a total of180mA from a 2.7V to 5.5V input. The current sinks maybe operated individually or in parallel for driving highercurrent LEDs. A low external parts count (two 1μF flyingcapacitors and two small 1μF capacitors at IN andOUTCP) make this part ideally suited for small, batterypoweredapplications.
