27C128 pdf datasheet
消耗积分:3 | 格式:rar | 大小:666 | 2008-08-07
golabs
分享资料个
The Microchip Technology Inc. 27C128 is a CMOS
128K bit (electrically) Programmable Read Only Memory.
The device is organized as 16K words by 8 bits
(16K bytes). Accessing individual bytes from an
address transition or from power-up (chip enable pin
going low) is accomplished in less than 120 ns. CMOS
design and processing enables this part to be used in
systems where reduced power consumption and high
reliability are requirements.A complete family of packages
is offered to provide the most flexibility in applications.
For surface mount applications, PLCC, SOIC, or
TSOP packaging is available. Tape and reel packaging
is also available for PLCC or SOIC packages. UV erasable
versions are also available.
A complete family of packages is offered to provide the
most flexibility in applications. For surface mount applications,
PLCC or SOIC packaging is available. Tape
and reel packaging is also available for PLCC or SOIC
packages.
评论(0)
发评论
下载排行榜
