FT2232D,pdf datasheet(dual USB
消耗积分:10 | 格式:rar | 大小:333 | 2010-02-16
韩刚龙
分享资料个
The FT2232D requires USB drivers (listed below), available free from http://www.elecfans.com, which are used to make the FT2232D appear as a virtual COM port (VCP). This then allows the user to communicate with the USB interface via a standard PC serial emulation port (for example TTY). Another FTDI USB driver, the D2XX driver, can also be used with application software to directly access the FT2232D though a DLL.
评论(0)
发评论
下载排行榜
