OB2203,pdf,Quasi-Resonant Flyb
消耗积分:5 | 格式:rar | 大小:322 | 2010-03-01
h1708587244.0670
分享资料个
OB2203 is a highly integrated Quasi-Resonant (QR)
controller optimized for high performance offline
flyback converter applications.
At normal load condition, it operates in QR mode
with minimum drain voltage switching. To meet the
CISPR-22 EMI starting at 150KHz, the maximum
switching frequency is internally limited to 130KHz.
It operates in PFM mode for high power conversion
efficiency at light load condition. When the loading is
very small, the IC operates in ‘Extended Burst Mode’
to minimize the switching loss. As a result, lower
standby power consumption and higher conversion
efficiency is achieved.
A built-in P-channel MOSFET and its control are
integrated to automatically turn on or off PFC stage
according to the load conditions. When used with
OB6563 (On-Bright’s PFC controller), the standby
power consumption of less than 400mW can be
achieved in typical 150W SMPS.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
