基于TGA2813-CP 下的3.1 to 3.6 GHz 100W GaN Power Amplifier
消耗积分:2 | 格式:pdf | 大小:0.49 MB | 2018-07-25
分享资料个
  Applications 
  Radar
  General Description
  TriQuint’s TGA2813-CP is a packaged high-power S-Band amplifier fabricated on TriQuint’s TQGaN25 0.25um GaN on SiC process. Operating from 3.1 to 3.6 GHz, the TGA2813-CP achieves 100 W saturated output power, a power-added efficiency of 》50%, and 23 dB power gain.
  The TGA2813-CP is packaged in a 10-lead 15x15 mm bolt-down package with a Cu base for superior thermal management. It can support a range of bias voltages and performs well under both short and long pulsed conditions. Both RF ports are internally DC blocked and matched to 50 ohms allowing for simple system integration.
  Lead free and RoHS compliant.
  Evaluation Boards are available upon request.
评论(0)
发评论
下载排行榜
