MT-076 TUTORIAL
Differential Driver Analysis
Differential drivers can be driven by either single-ended or differential signals. This tutorial analyzes both conditions using either an unterminated or a terminated source.
CASE 1: DIFFERENTIAL INPUT, UNTERMINATED SOURCE
Figure 1 shows a differential driver driven from a balanced unterminated source. This would typically be the condition for a low impedance source where the connection distance between the source and the driver is minimal.
