CAT310 pdf, 10 Channel Automotive LED Display Driver
The CAT310 is a 10−channel LED driver for automotive and other
lighting applications. All LED output channels are driven from a low
on−resistance open−drain High Voltage CMOS Nch−FETs and are
fully compliant with “Load Dump” transients of up to 40 volts. The
LED bias current of each channel can be set independently using an
external series ballast resistor, making the device ideal for multi−color
instrumentation displays.
