AAT3111 pdf datasheet
消耗积分:3 | 格式:rar | 大小:66 | 2008-08-28
分享资料个
The AAT3111 ChargePump™ is a MicroPower
switched-capacitor voltage converter that delivers
a regulated output. No external inductor is required
for operation. Using three small capacitors, the
AAT3111 can deliver up to 150mA to the voltage
regulated output. The AAT3111 features very low
quiescent current and high efficiency over a large
portion of its load range making this device ideal
for battery-powered applications. Furthermore, the
combination of few external components and small
package size keeps the total converter board area
to a minimum in space restricted applications. The
AAT3111 operates in an output-regulated voltage
doubling mode. The regulator uses a pulse-skipping
technique to provide a regulated output from a
varying input supply. The AAT3111 contains a thermal
management circuit to protect the device
under continuous output short circuit conditions.
The AAT3111 is available in a surface mount 6-pin
SOT23 or 8-pin SC70JW package and is rated
from -40 to 85°C.
The AAT3111 ChargePump is a member of
AnalogicTech™'s Total Power Management™ IC
product family.
评论(0)
发评论
下载排行榜
