Wideband Complementary Current Output DAC Single-Ended Inter
消耗积分:5 | 格式:rar | 大小:579 | 2010-06-07
贾永世
分享资料个
High-speed digital-to-analog converters (DACs) most often use a transformer-coupled output stage. In applications where this configuration is not practical, a single op amp differential to single-ended stage has often been used. This application note steps through the exact design equations required to achieve gain matching from each output as well as a matched input impedance to each of the DAC current outputs. An example high-speed design is shown using the very wideband, current feedback OPA695 op amp with additional suitable parts included in a summary table. A design spreadsheet program (described in this document) is also available for download.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
