LT3652HV PDF DATASHEET
Power Tracking 2A Battery Charger
The LT®3652HV is a complete monolithic step-down battery
charger that operates over a 4.95V to 34V input range.
The LT3652HV provides a constant-current/constant-voltage
charge characteristic, with maximum charge current
externally programmable up to 2A. The charger employs
a 3.3V fl oat voltage feedback reference, so any desired
battery fl oat voltage up to 18V can be programmed with a
resistor divider.
