Tag-it™ HF-I 13.56MHz 近程
消耗积分:2 | 格式:rar | 大小:1126 | 2010-06-30
分享资料个
The Vicinity Card Transponder from Texas Instruments is compliant with the ISO/IEC 15693 global standard for
contactless integrated circuit cards operating at 13.56MHz.  The card is based on TI's Tag-it
TM Smart Label
technology and allows interoperability of products from multiple manufacturers.  With a user memory of 2K bits
organized in 64 blocks, the 13.56 MHz card enables advanced solutions in a variety of markets, including access
control, security, ticketing, public transportation, production control, warehouse management etc..  This card can
be easily customized and personalized using standard thermo transfer printers. In applications where the card
needs to be used with a clip, we recommend a pouch since punching a hole would destroy the product. In addition
to the functionality defined in the ISO/IEC 15693 standard, the Vicinity Card Transponder also supports an
extended set of command options, providing more system flexibility.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
