CC1021 Errata Notes
消耗积分:3 | 格式:rar | 大小:286 | 2010-07-06
李霞
分享资料个
The carrier sense squelch function must be turned off in transmit mode in
order to enable the DCLK signal.
Description and reason for the problem
If the DCLK squelch function is used (enabled by setting INTERFACE.DCLK_CS =1),
this will prevent DCLK from operating in TX mode if not disabled.
评论(0)
发评论
下载排行榜
