Agilent 86100 Series 1.85 mm C
消耗积分:3 | 格式:rar | 大小:130 | 2010-07-08
分享资料个
The 1.85 mm connectors are used with many of the Agilent 86100 series plug-
in modules and remote heads. This manual will show you how to properly con-
nect, disconnect, and maintain 1.85 mm adapter/connectors.
Failure to follow the guidelines for proper connector handling and avoiding
electrostatic discharge (ESD) can result in severe damage to the product that
will not be covered under warranty. In some cases, the 1.85 mm connector is
an integral part of the electrical sampler device. Therefore, by using improper
cleaning and handling techniques, you risk expensive instrument repairs.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
