Introduction To improve the efficiency of process evaluation and characterization of semiconductor devices, automation of semiconductor test is required. However, analysis of the measured data and extraction of important parameters are difficult to automate. This application note shows you how to automate extraction of parameters using the unique auto analysis func- tion of the Agilent 4155C/4156C semi- conductor parameter analyzers, using the measurement of threshold voltage as an example.
