SN74AUC2G06,pdf(DUAL INVERTER
消耗积分:2 | 格式:rar | 大小:571 | 2010-07-12
张丽
分享资料个
DESCRIPTION/ORDERING INFORMATION
This dual inverter buffer/driver is operational at 0.8-V to 2.7-V VCC, but is designed specifically for 1.65-V to 1.95-V VCC operation.
The output of the SN74AUC2G06 device is open drain and can be connected to other open-drain outputs to implement active-low wired-OR or active-high wired-AND functions. The maximum sink current is 32 mA.
NanoFree™ package technology is a major breakthrough in IC packaging concepts, using the die as the package.
This device is fully specified for partial-power-down applications using Ioff. The Ioff circuitry disables the outputs, preventing damaging current backflow through the device when it is powered down.
评论(0)
发评论
下载排行榜
