SN74LVC3G06,pdf(Triple Inverte
消耗积分:3 | 格式:rar | 大小:505 | 2010-07-14
时见栖鸦
分享资料个
This triple inverter buffer/driver is designed for 1.65-V to 5.5-V VCC operation.
The output of the SN74LVC3G06 is open drain and can be connected to other open-drain outputs to implement active-low wired-OR or active-high wired-AND functions. The maximum sink current is 32 mA.
NanoFree™ package technology is a major breakthrough in IC packaging concepts, using the die as the package.
This device is fully specified for partial-power-down applications using Ioff. The Ioff circuitry disables the outputs, preventing damaging current backflow through the device when it is powered down.
评论(0)
发评论
下载排行榜
