MAX3440E, MAX3441E, MAX3442E p
消耗积分:2 | 格式:rar | 大小:555 | 2008-09-06
mintsy
分享资料个
The MAX3440E–MAX3444E fault-protected RS-485 and
J1708 transceivers feature ±60V protection from signal
faults on communication bus lines. Each device contains
one differential line driver with three-state output and one
differential line receiver with three-state input. The 1/4-unitload
receiver input impedance allows up to 128 transceivers
on a single bus. The devices operate from a 5V
supply at data rates of up to 10Mbps. True fail-safe inputs
guarantee a logic-high receiver output when the receiver
inputs are open, shorted, or connected to an idle data line.
Hot-swap circuitry eliminates false transitions on the
data bus during circuit initialization or connection to a
live backplane. Short-circuit current-limiting and thermal
shutdown circuitry protect the driver against excessive
power dissipation, and on-chip ±15kV ESD
protection eliminates costly external protection devices.
The MAX3440E–MAX3444E are available in 8-pin SO
and PDIP packages and are specified over industrial
and automotive temperature ranges.
Applications
RS-422/RS-485 Communications
Truck and Trailer Applications
Industrial Networks
Telecommunications Systems
Automotive Applications
HVAC Controls
评论(0)
发评论
下载排行榜
