SN74LVC1G18,pdf(1-of-2 Noninve
消耗积分:2 | 格式:rar | 大小:609 | 2010-08-09
笑过就走
分享资料个
This noninverting demultiplexer is designed for 1.65-V to 5.5-V VCC operation.
The SN74LVC1G18 is a 1-of-2 noninverting demultiplexer with a 3-state output. This device buffers the data on input A and passes it to either output Y0 or Y1, depending on whether the state of the select (S) input is low or high, respectively.
NanoFree™ package technology is a major breakthrough in IC packaging concepts, using the die as the package.
This device is fully specified for partial-power-down applications using Ioff. The Ioff circuitry disables the outputs, preventing damaging current backflow through the device when it is powered down.
评论(0)
发评论
下载排行榜
