The MAX8510/MAX8511/MAX8512 ultra-low-noise, lowdropout (LDO) linear regulators are designed to deliver up to 120mA continuous output current. These regulators achieve a low 120mV dropout for 120mA load current. The MAX8510 uses an advanced architecture to achieve ultra-low output voltage noise of 11μVRMS and PSRR of 54dB at 100kHz. The MAX8511 does not require a bypass capacitor, hence achieving the smallest PC board area. The MAX8512’s output voltage can be adjusted with an external divider. The MAX8510/MAX8511 are preset to a variety of voltages in the 1.5V to 4.5V range. Designed with a P-channel MOSFET series pass transistor, the MAX8510/MAX8511/ MAX8512 maintain very low ground current (40μA). The regulators are designed and optimized to work with low-value, low-cost ceramic capacitors. The MAX8510 requires only 1μF (typ) of output capacitance for stability with any load. When disabled, current consumption drops to below 1μA. Package options include a 5-pin SC70 and a tiny 2mm x 2mm x 0.8mm TDFN package. Applications Cellular and Cordless Phones PDA and Palmtop Computers Base Stations Bluetooth Portable Radios and Accessories Wireless LANs Digital Cameras Personal Stereos Portable and Battery-Powered Equipment
