SN74CBTU4411,PDF(11-BIT 1-LF-4
消耗积分:5 | 格式:rar | 大小:387 | 2010-08-13
刘润生
分享资料个
The SN74CBTU4411 is a high-bandwidth, SSTL_18 compatible FET multiplexer/demultiplexer with low ON-state resistance (ron). The device utilizes an internal charge pump to elevate the gate voltage of the pass transistor, providing a low and flat ron. The low and flat ron allows for minimal propagation delay and supports rail-to-rail signaling on data input/output (I/O) ports. The device also features very low data I/O capacitance to minimize capacitive loading and signal distortion on the data bus. Matched ron and I/O capacitance among channels results in extremely low differential and rising/falling edge skew. This allows the device to show optimal performance in DDR-II applications.
The device is organized as an 11-bit 1-of-4 multiplexer/demultiplexer with a single switch-enable (EN)\ input.
评论(0)
发评论
下载排行榜
