SN74CB3T3306,pdf(DUAL FET BUS
消耗积分:3 | 格式:rar | 大小:463 | 2010-08-16
王涛
分享资料个
The SN74CB3T3306 is a high-speed TTL-compatible FET bus switch with low ON-state resistance (ron), allowing for minimal propagation delay. The device fully supports mixed-mode signal operation on all data I/O ports by providing voltage translation that tracks VCC. The SN74CB3T3306 supports systems using 5-V TTL, 3.3-V LVTTL, and 2.5-V CMOS switching standards, as well as user-defined switching levels (see Figure 1).
The SN74CB3T3306 is organized as two 1-bit bus switches with separate ouput-enable (1OE\, 2OE\) inputs. It can be used as two 1-bit bus switches or as one 2-bit bus switch. When OE\ is low, the associated 1-bit bus switch is ON, and the A port is connected to the B port, allowing bidirectional data flow between ports.
评论(0)
发评论
下载排行榜
