SN74CBT16245,pdf(16-Bit FET Bu
消耗积分:5 | 格式:rar | 大小:334 | 2010-08-17
分享资料个
The SN74CBT16245 device provides 16 bits of high-speed TTL-compatible bus switching in a standard '16245 device pinout. The low on-state resistance of the switch allows connections to be made with minimal propagation delay.
The device is organized as two 8-bit low-impedance switches with separate output-enable (OE) inputs. When OE\ is low, the switch is on, and data can flow from the A port to the B port, or vice versa. When OE\ is high, the switch is open, and the high-impedance state exists between the two ports.
评论(0)
发评论
下载排行榜
