The SN74CBT16245 device provides 16 bits of high-speed TTL-compatible bus switching in a standard ’16245 device pinout. The low on-state resistance of the switch allows connections to be made with minimal propagation delay.
The device is organized as two 8-bit low-impedance switches with separate output-enable (OE)\ inputs. When OE is low, the switch is on, and data can flow from the A port to the B port, or vice versa. When OE is high, the switch is open, and the high-impedance state exists between the two ports.
