DS101_GGL301_Advanced_Datashee
消耗积分:3 | 格式:rar | 大小:344 | 2010-08-20
h1654155275.0032
分享资料个
The GGL301 is a single-chip implementation of a HomePlug® AV transceiver for inhome
networking over existing powerlines. By fully integrating all of the functions into a
single 100-lead TQFP package, the GGL301 provides the most compact and cost
effective solution for HomePlug® AV adapters and embedded applications.
Xtendnet™ technology is used to increase total coverage and throughput in larger
networks. Xtendnet™ enables each device to work as a repeater. So that each node
added to a network will regenerate and re amplify the signals over the powerlines.
The device consists of a fully integrated analog front-end, DSP based digital front-end,
HomePlug® AV Media Access Controller, RAM for buffer memory and control, an
advanced packet switching engine, and IEEE 802.3 Media Access Controller. The onchip
analog front-end includes a line driver that meets global requirements for injected
power and emissions, with bypass for applications needed an external line driver.
The device operates from a single 32MHz crystal, and can generate the 25MHz clock
commonly needed for Ethernet PHY devices.
评论(0)
发评论
下载排行榜
