TMDS141,pdf(HDMI Hider)
消耗积分:5 | 格式:rar | 大小:744 | 2010-08-23
其实znvm
分享资料个
The TMDS141 HDMI hider is designed to accommodate a 1-m HDMI cable between a HDMI connector and a receiver. The internal cable causes signal distortion to high-speed TMDS signals, as well as increasing capacitance to the DDC channel. Each TMDS141 contains four TMDS repeaters to transmit digital content with signaling rates of up to 2.25-Gbps, and an I2C repeater to link extended display identification data (EDID) reading and high-bandwidth digital content protection (HDCP) key exchange under I2C standard mode operations.
The device includes four TMDS compliant differential receivers with 50- termination resistors and 3.3-V termination voltage integrated at each receiver input pin. External terminations are not required.
评论(0)
发评论
下载排行榜
