SN75462,pdf(Dual Peripheral Dr
消耗积分:3 | 格式:rar | 大小:520 | 2010-08-30
370217
分享资料个
These dual peripheral drivers are functionally interchangeable with SN55451B through SN55453B and SN75451B through SN75453B peripheral drivers, but are designed for use in systems that require higher breakdown voltages than those devices can provide at the expense of slightly slower switching speeds. Typical applications include logic buffers, power drivers, relay drivers, lamp drivers, MOS drivers, line drivers, and memory drivers.
The SN55461/SN75461, SN55462/SN75462, and SN55463/SN75463 are dual peripheral AND, NAND, and OR drivers respectively (assuming positive logic), with the output of the gates internally connected to the bases of the npn output transistors.
Series SN55461 drivers are characterized for operation over the full military temperature range of -55°C to 125°C.
评论(0)
发评论
下载排行榜
